Thank you Baz - that means an awful lot!
The engine & gearbox combo are now off the stand as I was a little concerned that the bolts being used were under far more strain than they were designed for. Andy came over one evening and I built a little trolley for the engine, then we lifted it down. The alternator mounting bolts had indeed bent - I reckon they would've broken after a while. Note to self: when building a trolley, make sure that the castors you use can take the weight. The trolley now consists of wood, 3 wheels and some broken plastic...
I have practically finished off the heater; Having repainted the casing I have applied new foam to the matrix and the control flap then screwed it all back together. I still need to sort the switch panel but I can't make up my mind whether to re-use the original marking or get my own? I will have a think.
There are still some small bits needing work on the engine; a new oil pressure relief valve & spring went in with a new copper washer, and I have since turned my attention to the oil filter housing and pipe. Of course these were for want of a better phrase "bloody filthy" so I spent about half an hour giving them a good going over in the parts washer. Once dry, they've been primed then given a coat of silver to match the rest of the engine. I have also added the temperature sender to the head and have found the alternator bracket which I have also prepped for paint.
New foam and matrix going in.
Almost done. Needs a wipe down and switch panel sorting.
New oil pressure relief valve & spring in, along with new copper washer. Must touch up that bit I missed!!
