Gold Mk3 part search!
Post by axshack »
Hi all
I have discovered that the engine fan connector out of the loom is missing on my car - no wonder the fan never switches on !!
Rimmer brothers say there is no chance ever in getting a new, old stock, replacement !!
Does anyone happen to have one hanging about looking for a good home? Or....know where there just might be one ? :D
It is the twin conductor connector, oval in shape that fits into the side of the fan motor housing.
Cheers
Dave
Re: Gold Mk3 part search!
Post by streetsy »
Have you tried vehicle wiring products? They stock quite a range of connectors.
If all fails, you get get remote switches that are pushed between the radiator blades. Probably not as precise, but they are used frequently in the kitcar world because many cars use general purpose radiators without built in switches. Usually you can adjust the temp on which they need to switch on.
wolfie
Post by wolfie »
Dave can you put up a photo of exactly which bit you need please. I'm amazed by the amonnt of junk I've accumulated over the years so I may have what you're looking for
Post by axshack »
wolfie wrote:Dave can you put up a photo of exactly which bit you need please. I'm amazed by the amonnt of junk I've accumulated over the years so I may have what you're looking for
Hi Wolfie, it is number 4 on this drawing from Rimmer Brothers: http://www.rimmerbros.co.uk/ItemImages/ ... 000503.gif
Dave
Post by axshack »
Hans Efde wrote:If all fails, you get get remote switches that are pushed between the radiator blades. Probably not as precise, but they are used frequently in the kitcar world because many cars use general purpose radiators without built in switches. Usually you can adjust the temp on which they need to switch on.
Hi Hans, it isn't the switch I am missing, but the harness connector to the fan motor....seems to be so rare Indiana Jones might be needed to find one !! :D
Post by axshack »
streetsy wrote:Have you tried vehicle wiring products? They stock quite a range of connectors.
Good Idea, i had forgotten about those folks !
wolfie
Post by wolfie »
I'll have a look at the weekend. Got a couple of wiring looms so I should have 1
Post by axshack »
Thanks very much Wolfie.
Dave
Post by axshack »
it is the connector with the White/Green and White/Blue wires out of the loom to the fan
Return to “Wanted”
