Mk 3 Q705CPF
Re: Mk 3 Q705CPF
Post by axshack »
amazingly, today, the airlock cleared itself, before I got the chance to fit the bleed valve !!
I had this same problem with my Reliant Scimitar, the fitting of an expansion tank, higher than the engine fixed all airlock/overheating problems in a stroke !
Re: Mk 3 Q705CPF
Post by axshack »
..And finally, all fitted, heater plumbed in and working, fresh air vents working, Air/Fuel ratio meter ok and has confirmed my mixture was way too rich !!
Re: Mk 3 Q705CPF
That looks a rather tidy interior
Re: Mk 3 Q705CPF
Post by axshack »
Thanks Kelvink....I still have to do the flocking on the dashboard, as it is still in primer, but I agree, it is looking tidy !! :D
Re: Mk 3 Q705CPF
Post by axshack »
Have now got a very nice, tinted windscreen fitted by my local AutoGlass Special team !!
Went in a dream, and the rubber gasket I was advised to use, works perfectly.
Many thanks all for the pointers
See you on Sunday at Stoneleigh
Dave
Re: Mk 3 Q705CPF
Post by axshack »
..and finally, today had the windows tinted !
got Drug Dealer black on the back and rear sides and 70% tint on the doors....looking good ! Pictures later
Re: Mk 3 Q705CPF
Post by axshack »
While I had the front of the car off, i took the opportunity to replace my broken Cibie driving lamps.
These are mounted on the bumper and NOT on the monocoque as per the Cibie's
As you can see they are not recessed any more !
These are 6 inch RING driving lamps from http://www.cbsonline.co.uk
Of course, they have yet to be aligned correctly.
Re: Mk 3 Q705CPF
Post by axshack »
I think I have found the solution to not having enough room for a standard size battery in the engine bay and not wanting to run very expensive cable to the boot: A racing battery - to go with my Avonbar Racing engine @|@
Re: Mk 3 Q705CPF
Post by axshack »
..and here is another view....it is incredibly tiny....but powerful I understand !!
