brake limiter valve
mickyb
brake limiter valve
Post by mickyb »
Are re-ferb kits available for brake liminter valves ? have searched the net with no luck, am i just not looking in the right
places ! will it strip out by removing the large nut on the one end ? I have noticed that one of the ports is blind,not drilled
or tapped is this standard ?
Another question on valves,sorry, mounted on the plate that bolts to the clutch cover held on by 2 self tappers is a round
disc approx 2" dia x 1" thick with 2 lines running in, never seen one before, what is it ? have had it a brew of WD 40 etc, for the 10 days and have just managed to undo the fixed line, but the flexible is still rock solid, it does not look strong
enough to withstand locking up really tight in a vice to get extra leverage on it, looked on a lot of sites cannot see one,
but again maybe not looking in the right places, if they are not available, then it will just have to go back into the brew
for how ever long it takes.
Re: brake limiter valve
Post by streetsy »
Don't know about refurbishing brake valve, it is usual on minis that one port is instilled, the disc shaped object is probably a metro clutch damper.
