Hi Stuart
Thanks for the info !
But as you said , they are expensive but seems complete and well done , in time of urgent need that may be a solution .
I have already considered to put a round headlight of 5.75 inch ( 146 mm) with the round mounting ring and springs (the MKIII has 7 inch) the mounting ring costs +- 19euro and the headlight +- 38euro together 57 euro ( 41 pound )for a complete headlight , of course you should adapt some things ...
Also the combined hella light 90 mm (dimmed & beam) cost +- 86 pound /piece and more easy to adapt , only 90 mm diameter.
Headlight
Re: Headlight
Hi
I found some headlights which fit very well in my Midas MKII .
- 20150902_175302.jpg (1.77 MiB) Viewed 5485 times
Re: Headlight
dimensions headlight : see attachement
Disponible :H4 + duplo version , setsrews with fixing parts ,rubber seal , but ........not the mountingframe but easy........ to make
cost for 1 lamp +- 50€ all in ( not mountingframe !!)
comes from fiat 126/127
- BRN_DB2BF7_007749.pdf
- (152.07 KiB) Downloaded 608 times
