R1 into a mini
R1 into a mini
An interesting perspective of an R1 fitted into a mini.
I think it speaks for itself. Perfect for a Midas...
Re: R1 into a mini
Post by Alan D. »
Nice one David
It's chain drive,so not Promotive.
Any more information and the all important question for the new IVA test. Does it have a reverse?
Re: R1 into a mini
Hi Alan,
Yes I think it's the Pro-motive one....
http://www.pro-motive.co.uk/Customerscars.html
Still very very nice though!!! And its real! The other one is still a pipe dream until I see it.
I am not sure what the situation is with reverse. The Z car one did it with a flywheel and starter motor. I think it could be done on the
Promotive one too if a flywheel was attached to the front sprocket.
Does the new test require a reverse. Does an existing Midas need to go through the test?? :) I would think it wouldnt.
Re: R1 into a mini
Post by Alan D. »
Yes David,
You are correct. I'm getting it mixed up with the other one, where he designed and fitted a transfer box!
http://www.miniexvo.com/
Bit expensive,this kit!
Re: R1 into a mini
yes it is a bit. maybe the credit crunch might make these a bit more realistically affordable!
johnnyfixit
Re: R1 into a mini
Post by johnnyfixit »
or a different one to try ZX-9R photographed at Stoneleigh 09
either way the R1 looks more spacious
Return to “Miscellaneous”
