Mk1 Mk2 Bronze wanted
Killerwhat
- Contact:
Re: Mk1 Mk2 Bronze wanted
No Problem Tony.
Whatever suits.
Steve.
Whatever suits.
Steve.
Hi Steve,finally found my Term Diary,not all good news tho',exeat isn't until Nov 28th.Do you need to move the car before that date? It might be possible to get a Sunday off at a time amenable to both you & my mate Keith,but ONLY MIGHT be poss.,school isn't noted for flexibility.Let me know your thoughts,I AM KEEN.
Thanks, Tony
Thanks, Tony
Hi Steve, OK all fixed with my mate for the weekend Nov 28th,following a meeting with Kelvin,is the Gel coat cracked or crazed in any areas & how leak proof is it ? Neither are deal breakers I assure you, I just need to know ,in fact talking to Kelvin made my mind up to get a Midas.You've already replaced the rear beam so no worries there,if it leaks I've just got to keep my wife out of it until it's fixed!
Thanks ,Tony
Thanks ,Tony
Blimey I must be good given how rough my Midases look currently! I ought to ask for commissionsblunty wrote:in fact talking to Kelvin made my mind up to get a Midas.
Exeat, my god that brings back memories.blunty wrote:exeat isn't until Nov 28th.Do you need to move the car before that date?
Killerwhat
- Contact:
Hi Tony, sorry for the delayed reply, been away on the canals where there is no signal / Internet. In general day to day terms it doesn't leak as long as you keep the rear hatch channel drain clear of debris. If you start squirting hose pipes around tho I've noticed that water gets in round the fuel filler neck. Could probably do with a new grommet and a little silicon. Otherwise it's water tight. There is a small gel coat craze at the front, I'll send you a pic. Not sure what caused it, it's been there ever since I've owned it and hasn't grown. Which day we're you thinking of coming?blunty wrote:Hi Steve, OK all fixed with my mate for the weekend Nov 28th,following a meeting with Kelvin,is the Gel coat cracked or crazed in any areas & how leak proof is it ? Neither are deal breakers I assure you, I just need to know ,in fact talking to Kelvin made my mind up to get a Midas.You've already replaced the rear beam so no worries there,if it leaks I've just got to keep my wife out of it until it's fixed!
Thanks ,Tony
Killerwhat
- Contact:
Tony, I've added 3 more pics to the album showing the Gel coat crazing I mentioned. The other 2 show evidence of the Gel coat being polished so enthusiastically that the fibre strands are showing at the surface. Dad looked after cars religiously and I think in this case he might have been a little too sentimental !
If, ultimately, you are aiming for a concourse car then a respray is the best option but, as you can see from the photo's, it washes and polishes up well.
Steve ,thanks for the reply,hope the half term went well,OK, can't get the pics on screen but that might be my fault (not good with I.T.) ,would they be on your dropbox page yet,anyway as I said it's not a deal breaker.I can make Sat. or Sun. it's your choice, from my perspective I need to square it with my mate so if you let me know.
I'll need an address & maybe a phone number would be good.
Thanks, Tony
Thanks, Tony
Tony try this link it should take you to photos you are after.....
https://picasaweb.google.com/1070933150 ... directlink#
Killerwhat
- Contact:
This is the link to the updated album:
https://www.dropbox.com/sc/0mif1yglxt3h ... 1Q9eu1Vt0a
