Off cut of brass pipe, turned up a threaded boss also in brass and reused the bleed screw from my old rear coolant pipe,
Made up a stainless support
Painted and fitted
Seems to work
You are my inspirationbenofbrum wrote:That scuttle mod looks somewhat familiar, just better executed than mine.
If it has a spring it should be fine. But make sure the cap has the same thread as the tank. I wasn't able to find a replacement because of this, so had to replace the whole tank.Jin wrote:Found a Bearmach one on ebay with a brass valve - that's gotta be good hasn't it?
