Rover 200 dashboard
Mtrike
Rover 200 dashboard
Post by Mtrike »
My heater matrix is leaking but I can't work out if I can remove the cover over it independently of the front panel, anyone done this? If as I think I have to remove the front panel with the cover how do I do this? The build manual isn't very clear on this and it very firmly attached without any fixing to be seen unless their are screws under the vinyl covering.
Re: Rover 200 dashboard
On my car the heater panel is separate from the main dashboard structure so should be removable:
There is a separate build manual section about the Rover 200 dash on the archive site.
Mtrike
Post by Mtrike »
Mine seems to be one piece but it might just be the vinyl covering it. MOT on Tuesday then I'll try stripping it down. I've got the the 200 build but can't relate it to my dash, however my car is a pastiche so there may be differences.
Mtrike
Post by Mtrike »
I've been able to have a look now and it seems the dash mounding is a single piece of glass fibre. Pastiche must have made these for themselves. However it seems to be mostly held on by the dash fittings so dismantling begins, intrupted as retirement has been ended bu a job.
Return to “Mk 3 Convertible”
