Quick shift gear lever
Post by axshack »
Hi all,
I am going to fit one of these - mainly so the gear lever clears the instrument pod I built as the centre console !
Does anyone know if the the two pins that hold the gear stick ball joint in place can be drifted out, and if so, which way (inside out, or outside in)
the new gear shifter had two grub screws that obviously have to located where these pins are, so they have to come out !! :)
Re: Quick shift gear lever
Post by axshack »
is there predictive text on this forum? Because I am sure my grammar is much better than my last post would indicate !! :evil:
It's years since I fitted mine but I'm 99% sure that you just drift out the locating pins.
Post by axshack »
I agree, but I think they are tapered and look like you have to knock them out from the inside...just how you do that escapes me at the moment !!
Jvr19630
Post by Jvr19630 »
If i remember rightly they are not tapered but an interference fit
Grab and pull from the outside
wolfie
Post by wolfie »
heat the housing up and pull them with some pliers.....just watch for the grease that will ooze out if it's in the state mine was in
Post by axshack »
I drilled two holes in the tunnel and drifted them from the outside.
After a bit of a fight I finally got the new housing to line up with the holes and engaged the grub screws....and could not get gears 1 and 2 only 3, 4 and reverse....not sure what is amiss there, but I put the old system back while I think about it !! :)
Post by axshack »
Had a chat with MiniSpares (who sold me the quickshift system.....apart from the housing not seating correctly (checked and fettled), they can offer no other ideas why I cannot engage all the gears !
Anybody else fitted one of these? If so, what was the trick to get it right?
Cheers
Dave
wolfie
Post by wolfie »
mate had 1 and the nylon ball was too big so wasn't sitting in the rod right which stopped it selecting all gears. Ended up using some wet and dry to sand the ball down till it sat in properly. I find them notchy anyway compared to the standard 1 so in the midas I just chopped off a chunk of the stick and then bent the top slightly to get it where I wanted it
Post by streetsy »
Quick shifts also wear the socket out in the shifter much faster than a standard/shortened BL linkage so a liberal dollop of thick grease in the linkage may be a helpful once you have worked out your selection issues.
Return to “Mk 3 Coupe”
