16 by Roy Forrester, on FlickrHeadlight brackets.
17 by Roy Forrester, on FlickrHeater casing soaking in white vinegar.
18 by Roy Forrester, on FlickrThe vinegar worked a bit too well. The underside of the heater casing has rusted through but I have managed to locate another heater unit that's less corroded but the matrix was still shot.
I must admit it was the first time I tried vinegar and it does work quite well but for the best results its best to let the components soak for quite a few days and I like the fact that its nice and safe to use, no nasty chemicals. The only draw back if you haven't got a lid on the container my shed smelt like a pickle factory and every time I entered the shed and for the benefit of the mature forum members it reminded me of that old comedy program Nearest and Dearest, " Walter have you Beeeeen"
To a more serious note I finished the components off with the trusted wire brush.
19 by Roy Forrester, on FlickrAnd now to the painting.
20 by Roy Forrester, on FlickrThose brackets again.
21 by Roy Forrester, on FlickrHeater unit de-rusted and painted, waiting to be fitted back together.
Whilst in the mood for dismantling things I decided to strip the wiper motor apart to check there was no nasty corrosion lurking inside and to clean the body and you got it get the paint out again.
22 by Roy Forrester, on FlickrThe problem with this is when you clean one part it shows the rest up and then it becomes a vicious circle and before you know it your to do list becomes twice as long.
23 by Roy Forrester, on FlickrYou guessed it more cleaning and painting.
