So I am back from holiday after spending a lot of time in a car the other end of the size scale:
Glad I don't have to park that in England - it's a monster! Anyway, back to the smaller things in life. Today was a bit of a "tidying" kind of day in that I spent quite a lot of time underneath the shell with a paintbrush filling orange into all the little bits that the spray gun missed. I didn't bother taking any photos of this as a) it's brush-painted underside of bodywork and b) it's brush-painted so it isn't pretty. Most of it will be hidden anyway... Once I'd finished that I did a few other little bits, the first of which was making sure that the subframe could be bolted in nicely. Firstly I dug out the front mount brackets and spreader plates from the spares box. This was a simple "two bolts and nyloc nuts" job each side, complicated by the fact that the plates and brackets had so much paint on them that the bolts wouldn't push through. I sorted it with a old bolt and a hammer. At least I know they're not going to rust anytime soon...
I followed this up with a trial fit of the tower bolt mounts. I am using solid mounts as I like the idea of a) the better steering feedback and "point-and-squirtability" and b) never having to replace them again. As per usual on this bleeping car, there was a problem. When it was originally built, this Midas had a twin-bolt front subframe from a 60s Cooper S. It was converted to single bolt later, and when the holes were cut for the tower bolts, they presumably only had access to standard rubber mounts. These of course are flexible whereas the solid mounts are not, and the raised section on the mounts sat on top of the edge of the hole. There was just under 1/4" difference. My funky new cone cutters were not big enough, but because it's fibreglass, it's easy to re-shape. Out came my old friend the Dremel with a sanding band on it, and five minutes each side top and bottom saw the mounts fit snugly in place. Perfect. I also took the time to clean up and paint the large washers on the tower bolts as they looked a bit rusty and rubbish. I am unsure about painting the solid mounts as I don't know if the anodised finish is any good or not. Think I will leave them out for a few weeks and make a decision from there.
I have also made a captive nut plate for the wiper motor. I hated the way that mine was previously held on with big self-tapping screws - so I decided to do a bit better. Once the paint's dry I will drill the holes and fibreglass it into place.
Front mount plates in place.
Tower bolt hole midway through enlargement.
