tailgate adjustment
chad123
tailgate adjustment
Post by chad123 »
Hi all,
is there any adjustment on the tailgate glass,as mines catching on the bodywork
cheers
Re: tailgate adjustment
Post by fozzza »
Im afraid not. I had the same issue with my mk 2. Its the gas strut that pushes the screen over. I ended up carefully removing the screen and fitted some offset rubber bushes in the screen and re sealed the hinges back on. It hasn't moved as yet.
If there are no bushes around the glass to hinge pins then the glass can slide down quite a long way. Fozzza's come up with an easy solution.
Be careful with the glass and struts, a few people have managed to break the screen.
chad123
Post by chad123 »
Cheers guys,i will have a tinker with it VERY CAREFULLY
JUST FOUND OUT COMPLETE KITCAR WANT TO DO A LITTLE FEATURE ON IT
chad123
Post by chad123 »
Very carefully undone the strutt fittings and turned the bushes slightly, and now the glass fits properly onto the rubber
Return to “Mk 2”
