Fading Gelcoat
Re: Fading Gelcoat
Update..
I ended up getting hold of some G3 and spent yesterday wrestling with the buffer, I'm impressed with the results and I've now got a shiny Midas!
Re: Fading Gelcoat
Now you just need to keep it out of the sun ;)
I have the same problem with the GRP panels on my motorhome too, I have shares in Autoglym super resin, keeping the shine is rather time consuming, and the gel-coat will be getting ever thinner each time.
Re: Fading Gelcoat
I've polished it up with Meguairs which really comes up well, any idea how thick gelcoat is in comparison with paint?
Re: Fading Gelcoat
It's much thicker than paint. My car is missing a few chips her and there. A wild guess is that the thickness is around 1mm.
Cheers, Hans
Re: Fading Gelcoat
Thanks Hans, more or less what I thought. I'm pretty sure this is the first time it's been cut back as the finish was pretty good with just the odd swirl when I picked up the car, it's got much worse as it's been sat on the drive concentrating on the mechanical side of things.
Time to change my avatar I think....
johnnyfixit
Re: Fading Gelcoat
Post by johnnyfixit »
looks better with the polished bonnet on now :D
getting there wor kid as we say up ere
Re: Fading Gelcoat
johnnyfixit wrote:looks better with the polished bonnet on now :D
It's booked in for it's MOT on Wednesday!
Fingers crossed....
Bluto
Re: Fading Gelcoat
Post by Bluto »
G3 is a heavy cutting compound, ideal for removing heavy swirls/scratches, but not ideal for light swirl removal on gel coat.
I would be tempted to use CarLack which will remove some of the light swirls and of course not hologram.
If your going to do it to remove all the swirls, clay, ipa, compound, polish, ipa, protect.
