Mk2 rear axle
Re: Mk2 rear axle
Drawings to make the various brackets for the Bronze used to be readily available, however I've just tried to download them from the site and failed. Maybe someone on the site might have an original Bronze build manual?
The part you need appears to be DHM14. At the time I built my Bronze (1984/5), you could either make your own brackets from the diagrams in the build manual, or buy them ready made from the factory.
Re: Mk2 rear axle
Post by fozzza »
Having my manual to hand, I've scanned the drawing in question.
Image64 by Roy Forrester, on Flickr
If any more info is required from the manual just say the word.
centredonkey
Re: Mk2 rear axle
Post by centredonkey »
Thanks, Fozzza. Looks right, I'll check when I next stagger over to the barn where the car is stored.
Cheers, Colin
centredonkey
Re: Mk2 rear axle
Hi,
just reviewing the few posts I've made on the forum on a cold and wet Highland evening, now that the Midas resto is in full swing.
I'm deeply sorry to say that I've only just come across your kind response re my bulkhead bracket request.
Do you still have any of the stainless batch you had made?
Regards
Colin
Jvr19630
Re: Mk2 rear axle
Post by Jvr19630 »
Hi Colin, yes i have and pm sent
Return to “Mk 2”
