MrBounce
Re: Mk 1 Project Zippy - Engine is In! 01/04/17
Post by MrBounce »
I have been busy! Lots more to talk about so here we go...
The radiator is in! The new bracket fitted beautifully (and far better than the original one) and was eventually secured with a small M5 bolt. I have also attended to the wheels and spent quite a while filling and sanding all the minor imperfections in them. They're almost ready for paint (just need a wipe down with a rag and some spirit followed by a quick going over with a tack rag) and because the weather is good this weekend, guess what I might be doing??? I managed to get the oil cooler lined up and on its mounts. Just got to top it up and finish tightening up the bottom bolts.
Now comes the important bit: Tink came over and he brought his knowledge of wiring looms with him. I should point out that I have precious little knowledge of wiring and electrics, so having him come over was an absolute godsend. Firstly we laid out the loom to find out where best to cut holes in the body. When I bought the car, the loom came through the main bulkhead in a crudely hacked hole with no grommet. I didn't like this and really hated the way that it just was basically chucked around the engine bay. So we looked at alternative options. Another thing was that I didn't want the fuse box connections to be in the engine bay - a land of heat and dirt is not an ideal habitat for electrical gear. We shall work on that one. So rather than take the loom straight through a hole in the bulkhead, I started looking for alternatives, and the solution was REALLY simple. I have no intention of using the "fresh air vents" in this car (I have windows the crack open a bit for that job) so we kept the vent in the inner wing and removed the centre of it. We then fed the loom through the top of a spray can with a hole it in which fits perfectly over the vent. The loom was then channelled under the front wing until splitting into two for the engine loom and lighting loom. These were then fed through two newly cut holes (love the holesaw!!).
The loom has only got one thing connected so far - the oil light switch! More will follow once I figure out what this strange stringy things do...
Radiator in with much more clearance
Wheels filled and sanded - paint soon
Oil Cooler in
Loom laid out with Tink sorting what should go where
Through the air vent!!
And out by the battery...
...and the inner wing near the lights.
I now have to figure out what to do with all this!!
MrBounce
Post by MrBounce »
Not much work in the garage recently, mainly due to holidays and tripping over myself causing injury (not long-lasting!!). However, over the last couple of weeks I have managed to fit in some stuff, even if it's relatively straightforward.
First up was the exhaust manifold. This is a half decent Maniflow item, so I have given it a good going over with the wire brush on the grinder before a coat of VHT paint just to tidy it up. Kind of tempted by some Manifold wrap, but I am not convinced that it really works unless you get the really the expensive stuff - I think £9.95 on eBay for 10 metres would be a non-starter. Thoughts anyone?
The wheels have also been primed and painted. It's far from a completed job - they need at least another coat and also some lacquer. I do like the way they look mind...
Manifold cleaned up...
...and painted with VHT.
Meanwhile, at the front of the garage, wheels in primer...
... and in Black.
MrBounce
Post by MrBounce »
I have discovered a few things since my last installment. There are as follows:
1. Lacquer is great stuff but man does it stink. I have now given my wheels 4 coats of lacquer and I think they look rather nice. As they're a home-sprayed job they'll never be as perfect as those that have been professionally reconditioned and powder-coated, but then I'll have the satisfaction that I did them myself at a fraction of the cost.
2. I have found somewhere for the coil to go. I did not have a coil bracket which bolts on to the head stud - and I didn't like them much anyway. Instead, as I'd moved the solenoid, I whipped off the bracket I'd made up and modified it, then flipped it round for clearance. The coil now sits nicely there, and just for fun I put on the dizzy cap and leads for that "almost-finished" (yeah right!) under bonnet shot.
3. I am a prize plonker. I had dragged out my front indicator/sidelight lenses with a view to removing the rather sad-looking "chrome effect" surround that was painted on the inside sometime in the 70s. Some careful sanding removed this. I then spent several minutes carefully masking up the lights and hanging them up ready for paint. I then primed them. Do you see what the issue is here? Yup. Stupid ol' me primed the inside of the clear lens. I think to make it easy on myself I shall simply re-mask and spray on the outside. That's a bit easier than taking it all off again. Either that or I'll see how good it looks with the grey...
One of 5 beautiful shiny black wheels. I will be letting the lacquer harden suitably before even considering tyres...
New coil on its new bespoke bracketry.
And a pretty shot to show that I know where the leads go.
Shabby silver surround on sidelight lens before I removed it. I need to repair the screw hole where the old screw was rusted solid...
All masked up ready for disaster
MrBounce
Re: Mk 1 Project Zippy - Never Ending Jobs...
Post by MrBounce »
Another quick update for all you lovely people who follow my rebuild.
I had a look at the light lenses having removed the masking tape and the result was not that great, so it was on to plan "B". I got out the 180 grit and keyed the outside edges of the lenses then remasked it and chucked on a couple of coats of satin black. I know it's not exactly the most noticeable aspect of this little car, but it's the little things, right? :D
I was also fed up of stubbing my toes on the exhaust manifold so it was time that went on the car. The thing was, could I remember where the manifold gasket was? Yup, that's right, on top of the garage stereo which is on a shelf under the workbench (obviously). It's often the case that Mini LCB manifolds and the separate inlet manifolds don't match up well and either require grinding or stepped washers to seal properly. Luckily, I'd bought a (secondhand) Maniflow LCB, and some quick checking with the digital calipers revealed a difference of 0.05mm - I'd say that's close enough! Also, I am led to believe that some people have difficulty fitting LCBs to Minis as they're a tight squeeze. Well, not on this Midas. It took about 30 seconds for me to get both parts hanging on the manifold studs - it must all be about the angle of the dangle... On went the inlet manifold and I nipped up the nuts, including the REALLY awkward one 3rd in from the clutch end. I used to have the perfect tool for this - a 3/8" ratchet with a uni-joint and a deep 1/2" socket. I think that the socket ended up in my friend's toolbox several years ago so I had to make do with an alternative in 1/2" ratchet flavour. Still, it's all on and looks great. More to follow!
Outside edges of the lenses now in paint - here's hoping that it looks a bit better this time...
Manifold hanging on the studs...
...and all nipped up with its inlet brother.
Post by Jin »
Nice work mate.
Intrested to see how the lights come out
goldeneye
Post by goldeneye »
always nice to see your lovely pictures!
Midas Mk II
MrBounce
Post by MrBounce »
Thank you Goldeneye!
Well it's time for an update, even though it's quite a small one. I have been struggling for time recently, so I've only got a few minor things done. However, I can report that the painting of the sidelight lens edges was a success. There's some minor overspray which should clear up easily but overall I think it looks rather good. I've also managed to repair the hole in the lens where the screw goes through. Some careful use of epoxy resin saw that the hole was a thing of the past.
One thing that I have only just remembered AFTER I have started putting the car back together was that the throttle pedal fouled on the wheel arch slightly, so full throttle would be difficult. I had meant to amend this when it was all in bits, but like most good ideas, I didn't write it down so therefore didn't remember. Removing the subframe, filling then redrilling the current mounting holes was a "Hell No!" idea, so I just decided to "amend" the pedal using Tink's welding skills and some metal bar. It' simple, it should be effective and if you think it's not that pretty, well I don't care coz you won't see it anyway!! Beats ripping the whole car to bits to do one small thing!! I haven't trial fitted it yet but that's on the list of "to-dos".
Finally I went to fix the K&N air filter to the carb. And found that I couldn't. This will be because it's for a 1 1/2" SU carb. My carb is 1 3/4". Whoops... I shall see if Tink's got a spare one.
Lenses look good.
Amended pedal with extra metal. Functional.
MrBounce
Post by MrBounce »
In between tidying up lots (house move next year), I've done a couple more minor jobs. A friend came up with a lovely looking K&N filter which fits beautifully, apart from the fact it fouls on the heater control. I may have to do a little bit of rethinking in regards to this - I may have to do some cutting and shutting with the heater pipes. I shall investigate further.
I've also mocked up the top hose arrangement - all fits together nicely - i just need to get myself some more hose clips as the ones I have are all old ones. Not that I don't trust them, but they look a bit rubbish.
I will update with further little jobs as time allows...
New filter. Looks awesome and fits well, except the heater valve is in the way...
Top hose arrangement under initial trial. New hose clips needed!
Yes that tophose wil cause troubles, can collapse easily causing the engine to overheat. It's much better to use a hose that has the corner moulded in, or buy a separate elbow and connect it to the straight tube. This is the way I have it on my Midas.
MrBounce
Re: Mk 1 Project Zippy - Lots of Little Jobs
Post by MrBounce »
Hi Hans
Thanks for your suggestions - it is an initial trial, however the hose shown is moulded to a 90 degree angle so should be ok. I am considering a 90 degree pipe though - watch this space...
There will be precious little work done on Zippy in the next month or so as we have the delights of a house move to sort out. That said, I have managed to do one small thing I have wanted to do since buying the car: sort the fuel cap properly. The problem I had wasn't the cap itself - I'd reconditioned it by giving it a coat of fresh paint and replacing the knackered foam with some fuel-proof rubber. That said, it wasn't perfect and the seal was knackered. All the Triumph TR7 specialists do not stock a new seal for the big cap (this was only used on the early TR7 fixedhead models for about 18 months) and I have never been able to find one on the bay of e. I then decided to search on the TR7 forum www.tr7triumph.com/forum/ on the off chance. It turns out that one of the members has indeed commissioned new ones at the decent price of £12.50 including delivery. So a brief email exchange and some excellent work by Postman Pat saw the new items on my doormat yesterday.
Fitting was relatively straightforward (although getting the screws undone is awkward as you have to angle the screwdriver), and it was eventually all back together and looking VERY smart. I shall report more once Zippy has been moved to his new home.
New seal and foam backing obtained from the extremely helpful TR7 forum
Old seal really was in a dreadful state
All fitted back together on the bench
And a view from the front. Lovely.
