xxxxxxxxxxxxxxx
Re: Grey carpet to match 1988 corby factory fit
Hello,
You could try these. Send them a piece (they're based in centre of Manchester) and see what they can do. I found them very accomodating.
http://www.segalmotortrimmings.net/
Kind regards,
Kind regards,
On my first coupe the footrest areas were worn out, so I bought a few meters nice quality woven dark grey doormat at the DIY store (they have it on a roll). It is useful for in front of the seats and just behind, because it is very strong, blends quite well with the lighter grey of the walls and doesn't show dirt. Saves you the trouble of finishing off the edges as well, because it is just cut to shape.
Obviously it is useless when you need to replace the luggage area or tunnel because of its stiffness.
