rear suspension coilover MKII
Re: rear suspension coilover MKII
correct, which is a shame and why I said "I guess the rear ones could be modified to hold a spring too"Geoff Butcher wrote:As far as I can see KYB don't do coilovers.
I am running with 90lbs (2.25", 10.5" Length ) to, and I like it a lot, just as stiff as my mini. But as always, maybe there is still a better set-up around?fozzza wrote:I totally agree. I have GAZ dampers with 90lb springs on the back of my MK2 and it feels quite harsh. I suppose the best comparison is like the Princess and the pea. Its not so bad when we go away for a few days with a full fuel tank and the wife has packed the kitchen sinkStuart wrote:Do not buy GAZ dampers, the damping rate is too high I understand.
Protech may be your best option for a shorter damper, spring rate from 90lb/inch to 110lb/inch, 2.25" diameter springs.
http://midasownersclub.co.uk/forums/vie ... +coilovers
these are the best mini shocks, I guess the rear ones could be modified to hold a spring too https://www.minisport.com/kyb74304kit-k ... rbers.htmlbut you cant always travel fully loaded up. so I also would not recommend.
I have purchased Protech for my MK3 but have not put them to use yet, so Im pleased that Rich has recommended them.
Midas Mk II
