I have bought two sets of LED headlights for the Pastiche ahem …. Midas.
These are the fellas
https://www.ebay.co.uk/itm/2x-5-3-4-5-7 ... 1438.l2649
Now this might seem a silly question but how do the old units come out - I see what look like clips but they are close to the bodywork so allow no movement. I guess the assemblys are removed - some fixings are visible from the engine bay but I figure these are what sets the beam heights?
My inspiration being the red MK3 coupe with the same angel eye LED units fitted to main beams pictured variously on here - my little ruffian is getting a matching pair 5.75" below as well.
Surprisingly cheap - last time I looked a pair of very similar LED Speaker units would have cost over £700. Both sets E marked and total cost about £125. Bargain?
LED Headlights to a MK3
Re: LED Headlights to a MK3
I note that in the sellers shop is also listed a 7" x 5" duel beam headlight. Is this the right size for the mk1 &2
certainly the right size, they look like the trucklight in this video, or a copy
https://youtu.be/6ifsEY7KbBg?t=15m42s
https://www.ebay.co.uk/itm/Rectangular- ... SwE0JY-cXk
Update
The lower units had to go back as they are too big behind the rim - the alloy casting will not fit within the Cibie mounting rings.
Looking at options - a more conventional LED unit appears to be considerably smaller in side profile.
David Stephens - Axshack on these pages - fitted LED lights to his Mk3.
DSCF6338 by Alistair Courtney, on Flickr
I had a quick search to see if he had mentioned where he got them from, but only found a thread where he describes the various electrical issues he had fitting them - http://midasownersclub.co.uk/forums/vie ... y&start=10
DSCF6338 by Alistair Courtney, on FlickrI had a quick search to see if he had mentioned where he got them from, but only found a thread where he describes the various electrical issues he had fitting them - http://midasownersclub.co.uk/forums/vie ... y&start=10
Hi Alistair
The main lights are fitted and working it's the lower driving lights that will not allow the fitment of a similar led unit. Too big at the rear.
Have an option on variation on the theme but not quite what is wanted and coming from China if I buy I own. So still pondering.
The led mains do update the front end imo? But the cuffs need to match the collar.
