Front subframe
Front subframe
Are the front subframe mounts the same as on the MGF/TF?
Re: Front subframe
Hi Geoff,
The front (front subframe) mounting bushes are the same as the MGF/TF and Rover Metro, but the rear (front subframe) mounting bushes are different. They shortened them on the Rover Metro (K-series) so that they used only two bolts rather than three.
Alistair
Return to “Mk 3 Coupe”
