Filler pipe
Filler pipe
Post by Jin »
Am I right in thinking the standard rover metro fuel filler pipe needs cutting down / shortening to fit into the mk4?
I ask as the replacement rover 100 3dr filler pipe I have purchased looks the same but longer?
Any help much appreciated
Thanks
Re: Filler pipe
The build manual states "The filler neck and venting tubes should be located and fixed as per the Haynes manual."
However, I have seen the necks shortened and I guess that is to get a better run with the flexible pipe section. If the current arrangement looks good then I would suggest taking a measurement off the old filler neck.
Re: Filler pipe
Post by Jin »
Thanks mate much appreciated.
I had read that also but assumed it had maybe been amended at a letter date?
To get my new one to resemble my old one I'd have to cut athe least 6 inches out
Return to “Mk 4 Cortez”
