To cheer myself I cut a hole in the dashboard. Why? Because every car needs a starter button. I had one on my red Mini (a "Push Once" button from a bus!), and also a less extravagant one on my Golf GTi - these were notorious for having ignition barrel issues, so I simply bypassed the issue. Plus I like them. I did consider getting another bus button, given I bought the last one in 1999 for 50p from a breakers yard, but as with most things from the 70s and older, silly tax gets added today. I am not paying £20 plus for one! I grabbed a normal one I had in a parts box and made an appropriate 22mm hole using the cone cutter. It fits beautifully.
I then moved on to fitting the 4 main switches I'll be using. These are the standard Mini Lucas switches - all new ones - headlights/sidelights, fog light, brake test switch and of course hazards. Trouble was, getting the holes cut for them posed a problem. I couldn't get the Dremel in and accurately cut the holes for them. Instead, using a Mini switch panel as a template, I drew an outline of where the switches should be then used the drill to make a chain of holes and once I had been able to remove the unwanted piece of dashboard, I tidied the rest up with a file. At least that's what SHOULD have happened. In fact what I did was to rush and not concentrate on what I was doing. i somehow managed to drill the top holes 3mm too high. So out came a piece of tape covered card, and I stuck this to the front of the dash. I then filled in the holes with resin.
Having finished swearing, I did some more sanding (my favourite pastime) and set everything up again. This time it went without much of a hitch, and the switches fit really nicely. I have finished it off with some more filler, as of course there were some imperfections I had missed and some problems reared their ugly heads when I had painted the dash - paint droplets I am looking at you!! It will look nicer once the dashboard has been painted. Again. I do so love doing things twice...
Painted dash (at least the bits I could reach) looked ok from a distance...
...but paint issues were all too apparent.
I fitted a starter button.
Then marked out where I wanted the switches to go.
I promptly then cocked it all up and drilled in the wrong place, because I am stupid and rushed it without concentrating. I filled in the holes with resin.
I don't like chain drilling because it's a bit messy but it tidies up fine (picture taken BEFORE the filing!!)
Switches fitted. Foglight looks slightly "out" but I can assure you it looks fine head on.
And a bit more filler to tidy it up. More sanding to follow. Whoop di doo.
