Parts for sale
Parts for sale
As I have now handed over my Midas MK3 Gold Coupe to the new owner I have lots of parts for sale that I have gathered over the last 6 years. Some of the parts are Midas specific others are standard Metro. The items are listed below if anybody is interested in anything please let me know before I put them on Ebay. I have pictures of most of these items if needed and most are new.
Thanks, Russell
Gold rear bumper in burgundy
Handbrake cables x 2 modified by Speedy Cables.
Hrdrolastic pump in excellent condition
Rear radius arms
Suspension globe
Clutch master cylinder
Rev counter
Mg Metro Clocks
Borg and Beck clutch
Indicators
Anti run on valve
Brake master cylinder
Ball joint
Steering coupling
Top radiator hose mk2 rad
Inner CV joint
Front subframe mountings
Front disks with drive flanges
Verto clutch kit
water pump
Clutch slave cylinder
Temperature sensor
Borg and Beck clutch arm
Oil pressure switch
SU carb dashpot damper
Lower suspension arm
Front wheel bearing
Outer CV joints
fuel sender unit
Fuel pump
Bottom radiator hose
Rear wheel bearing
Ignition lock with 2 keys
Suspension knuckle joint
Flywheel bolt both types
Loads of engine mountings
Thanks, Russell
Rear radius arms
Suspension globe
Rev counter
Mg Metro Clocks
Indicators
Anti run on valve
Ball joint
Steering coupling
Inner CV joint
Verto clutch kit
water pump
Temperature sensor
Oil pressure switch
Front wheel bearing
Outer CV joints
fuel sender unit
Fuel pump
Rear wheel bearing
Re: Parts for sale
Hi Russell I am interested in some of the parts you have for sale, the brake discs with drive flanges are they vented discs also what condition is the rear bumper?
Cheers Bruce.
Cheers Bruce.
Re: Parts for sale
The brake discs are vented and are genuine Lockheed ones still with the protective grease on. The rear bumper has been repaired at some point and resprayed. I can send a photo if you give me your email.
Re: Parts for sale
Hey hey, so Paul Ryan bought your Midas. Hope to greet him on this forum.
Re: Parts for sale
Hi again russell I will have the discs and flanges off you how much do you want for them.
Thanks again Bruce.
Thanks again Bruce.
Re: Parts for sale
Bruce, make me an offer, but not a daft one. You can mail me at russell@quantum54.freeserve.co.uk if it is easier. Where in the UK are you?
Re: Parts for sale
Aberdeen.
Re: Parts for sale
The following items are now sold:
Radius arms
Brake disks
Outer CV joints
Front wheel bearing
Rear wheel bearing
I think I have a new fuel tank as well but I need to get the box out.
Russell
Radius arms
Brake disks
Outer CV joints
Front wheel bearing
Rear wheel bearing
Russell
johnonthetyne
Re: Parts for sale
hi russel , hope tour well, long time eh? what price is your hydroelastic pump? johnb.
Re: Parts for sale
Hi Russell,
I would like one of your handbrake cables and the ignition lock for my Gold Convertible.
How much inc P&P?
Regards,
Martin
How much inc P&P?
Regards,
Martin
