grease points - where and how many
paulr
Post by paulr »
hi all , just starting to find our way around our midas - can anyone tell me please what grease points there are - where they are and how many - thanks - don't want to miss any
Paul
Re: grease points - where and how many
There are 4, one on each suspension. Front upper A-arm, rear at the end of the suspension axle (just behind the small cover). If you haven't already pick up a Haynes Metro manual from Ebay. Here's a brand new one for 1p:
http://cgi.ebay.co.uk/Austin-Metro-1980 ... 2a076119de
Just forgot, the Corby doorhinges are notorious for wear causing the doors to sag. Later versions from GTM have grease nipples.
Door hinges on the Midas......
Im thinking of taking the pins out and putting a turned steel pin in retained with an r clip and washer so I can take the doors off easier (for working in those shitty under dash areas)....plus you can grease the pins too....or go commando in the summer :).
paulr
Post by paulr »
eureka - been playing with our midas tonight and found 4 grease points - 2 for rear suspension arms and 2 at front -please yell if there are any more we have missed ?
thanks
Post by Rich »
paulr wrote:eureka - been playing with our midas tonight and found 4 grease points - 2 for rear suspension arms and 2 at front -please yell if there are any more we have missed ?
thanks
Just the door hinges as mentioned above, assuming yours has nipples fitted.
Return to “Mk 3 Coupe”
