Hi!
I have just become the owner of above which is on a "D" prefix reg no. but I'm guessing its a bit older than this, can anyone tell me what year this was manufactured?
I'm assuming it is a Mark two, as it has the flared "stick-out" wheel arches, and the front bumper with two cut-outs for spot lights.
It is British Racing Green gel-coat and in need of some restoration, having had many owners and been off the road for many years, but I promise I will do my best to get her back on the road!!
Cheers, Dave.
MIDAS BRONZE CHASS NO DO 20342 D3
alberto midas
Re: MIDAS BRONZE CHASS NO DO 20342 D3
Hello Dave,
Your MIDAS is a Midas Decathlon , body manufactured in 1989. Mine is a Decathlon chassis number DO 20340 which was the last one to leave the factory although yours has a later chassis number! If you look at reg Q867WTY under mk2 in dead or alive you can see mine!
Good luck with the renovation.
Alberto
Alberto
d.woodspeed
Alberto,
Thanks for that, I did'nt realise I had bought a special edition!!!
Your's looks good, gives me a goal to aim for!
What size wheels/tyres does yours have, 12" or 13" and how wide? This is something on my shopping list, but I don't want to run in to clearance problems, so this would be really useful info.
Regards, Dave.
Regards, Dave.
alberto midas
Dave,
Mine has standard Mini 12 " 4 1/2 " wide alloy wheels at the front and Minilight 12" 5 " wide at the back. The tyres are Yokohamas A539 165/60 12 front and back. It use to have Minilight 5" at the front as well but I damaged one and put some spare wheels I had from a mini . Bye the way the Mini ones will not fit at the back with these tyres as they rub against the coil springs.
Alberto
Alberto
