On the highway, the car felt a bit unstable. First I thought it was struggling a bit with the tracks, because the wheelbase is not as wide as the wheelbase of an avarage car. Then I noticed it's only when I release the throttle. The car starts to waggle a little bit and it feels like the read end wants to overtake the front end. Something that's quite logical for a car that has the weight of engine and passengers all on the front end.
Is this a problem that you also have with your Midasses? And how have you solved it? Should I put some stones or bags of cement in the back to balance the weight?
Or maybe it helps to have a lower tire pressure in the rear tires?
