heres a couple pics of mine from inside....
with err..... temporary 'extra ventilation'. I might redo these seat wells the same as the later ones. Easy enough to do.
David,manifold wrote:Them seats look good there Alan!
Only thing I would suggest is that the seats are raised with stainless 1 or 2 inch box section (depending on body height) the length of the runner which is what I have done on both now, shimmed up with the odd stainless penny washers to miss the bumps in the runners (if any). I used the plastic spacer bushes a few years ago and found it a bit weak on the support for the seat runners, but then again, maybe my bushes weren't fat enough LOL.
It does seem to explain the scuttle shake. 15mm difference. Quite a difference that....its half as much again! I didn't realize that. I wonder why GTM decided to do that. The tunnel area on my convertible is quite thick. Probably thickest part of the car, must be approaching 3/4 inch thick there, and the inner sills are an inch thick, maybe more, but have foam sandwich in them. The holes for the seatbelt fixings are really deep down and I needed longer bolts to fit them. The standard bolts weren't long enough.
