rear coilover brackets for midas gold
if i can get the time to finish the car off by stoneleigh i will be very happy but its not looking good have to work more than ever at the moment i have not got a great deal left to do really its just like a giant jigsaw plus the rear coilovers are expensive when is stoneleigh
Its usually first bank holiday in may
mines polished underneath dont worry im hanging my head in shame
Already polishedmanifold wrote:are you going to polish it underneath too?
Come on David don't let the side down, get the polish out
you must be kidding lol.
Reason I went for Ti was so that I dont need to clean it
im going to get the same for mine eventually is it alot of work
not so much a lot of work, as a lot of cash. your looking at around 1k for a rear subframe assembly and radius arms.
problem doing it yourself is finding someone who can work with Ti. You need the right tooling and a welder who specialises in Ti as it needs welding in a purged environment. This is because it burns in air under heat. A bit like magnesium does.
i found some on a thread ready made will they need welding if so i doubt i will be able to go down that route
ready made what? Ti radius arms?b1zbaz wrote:i found some on a thread ready made will they need welding if so i doubt i will be able to go down that route
They can be bought, but you would have to order them. I didnt do any welding.
I designed the outline of the rear arms and subframe, using some ideas already around...... Drew it up and Carl Austin made it for me.
Well actually I also took a cut down subframe and a metro radius arm as reference points for the design too.
Not sure, but Carl might have made some jigs.
