Speedo cables
Speedo cables
How many different Metro speedo cables are there? The one on my car fitted the old (Smiths) speedo but not the present (Veglia?) one, although it's been working quite well until now just pushed in loosely. Now I have the dreaded needle twitch again and I don't know whether it's the cable or the instrument.
Re: Speedo cables
The needle twitch on my second Midas (and the only time I experienced it) was caused by a binding cable. I suppose the life of these cables is about 20 years.
Re: Speedo cables
I would say so, it is different than the ones I have on the older type pod.
Re: Speedo cables
That's the one I have for the Metro mk1 clocks where both the rev-counter and speedo are round.
The first one is for the Metro mk2 pod where the rev-counter is just half an arc or so.
Re: Speedo cables
Does that mean the Mk2 Metro cable plugs straight into the Rover 216 dash? It Looks like it does. I never knew that.
Re: Speedo cables
Highly likely David.
Off topic, I've just got a new fuel-pump to try on my car, it's only a QH copy one.
Re: Speedo cables
Stuart wrote:That's the one I have for the Metro mk1 clocks where both the rev-counter and speedo are round.
Both my clocks are round but it's a Veglia unit which according to Haynes is on later cars, Smiths on earlier.
I'm getting more confused!
Re: Speedo cables
the later mk1 metro pods were also veglia from memory
