I thought I'd have a look at getting the dashboard out as there was bound to be more than a few horrors behind it. Amazingly, the fibreglass shell (with the middle bit which looks like a failed Star Wars character's helmet) came off really easily leaving behind another piece of fibreglass. However, this bit is bolted on at the ends so I won't be taking this off until the doors come off. It's also riveted to the main metal crossbrace so I have drilled out the rivets to make extraction easier. I'm still not sure about the what/how of the dash I'm going to use but hey, I've got time
I turned my attention to the rest of the interior: the sill carpets needed to come out. Got as far as the driver's side seatbelt mounting and as I removed this I was a bit shocked to find that once the bolt was out water poured into the car!
I thought this was down to the drainage channels being blocked but further investigation revealed something else. There were two speakers in rear three-quarters so I removed them. The driver's side was nasty: it was stuffed full of underlay and old newspaper which was soaking wet, probably from the damaged seal on the small window. It dates from May 1981, about 3 months after the car was registered. A quick delve in with my hand revealed a couple of inches of water in the bottom. Still not sure how I'm going to get this out without a Vax-style hoover. We shall see. I can't get a spanner in to undo the seatbelts which attach to the rear heelboard - I need to have a closer look to see how I can do this without destroying the belt housing. I'm not going to use them again anyway, as I don't really trust a 30-year old seatbelt that's been sat in a damp car for 10 years, but I'd prefer to get 'em out the proper way without damaging too much!
The boot area was quite easy to get all the trim out of. The fibreglass side panels came out easily without a fight and even the big flexi pipe for the fuel tank was a doddle. I even removed the rear numberplate; Underneath is the cleanest part of the car. The seatbelt clips that bolt through the floor won't come out until I've got the Midas up on axle stands. I may be losing weight at the mo but I do not fit under there to get a spanner on the nuts.
There's a random small hole in the boot floor, and I have no clue why. Any ideas?
I also removed the front bumper (2 screws!) and had a quick look under the bonnet again. I am definitely thinking of a new wiring loom - possibly taking a Mini one and bridging / removing where necessary as the front loom does not look that healthy. More later
Dashboard under the fibreglass cover
Horrid 1981 Sharp speakers which went straight in the bin
Clean boot area
Random hole in the boot floor
Sodden underlay. This stank.
May 1981 Croydon Borough News (Wonder if they caught the thief?)
Clean interior but with seatbelts still attached
The cleanest bit of the whole car!
Bumper gone in about 2 minutes and still in one piece!
