Wiring Loom Help Required
PeteH
Post by PeteH »
Hi
Does anybody recognize this part from the wiring loom of a Metro GTi which I am trying to place in my 2+2 Coupe? If so, what is it and where does it fit?!! :?
Thanks
Pete
Re: Wiring Loom Help Required
Is it a throttle position sensor?
PeteH
Post by PeteH »
Panic over - went through the wiring diagrams and it connects to the ignition switch!!! :D
Post by manifold »
looks suspiciously like the bottom of an ignition barrel to me. I could be wrong but they look like the 2 brown live wires.
PeteH
Post by PeteH »
Thanks for your replies - it is the ignition connection from the base of the key barrel!
Fast forward to the next problem!
Pete
PeteH wrote:Thanks for your replies - it is the ignition connection from the base of the key barrel!
Pete
Frequently seen hanging from under the steering wheel being actuated with a screwdriver.........
Damn, I'm glad I moved out of Bradford..
PeteH
Post by PeteH »
yes, those damn screwdrivers are everywhere, lock up your Midas.
Return to “Mk 4 Cortez”
