LCB for Midas
- minisweden
LCB for Midas
Was browsing Minispares website for a nex LCB, the castiron manifold on mine is looking a bit worse for wear...
Came upon this: MANIFOLD METRO LCB LMO22 very similar to C-AEG365 but 0.375" shorter to fit in the metro mini engine bay but also ideal for small bore engines and some 970/1071 cc cooper S
My question is, would a shorter Metro LCB be a better fit than a standard for the Mini?
Had no idea they were different.
Re: LCB for Midas
If you have a gold mk3 the metro one is the one you want.
- minisweden
Re: LCB for Midas
Thanks, I´ll order one tomorrow.
- minisweden
Re: LCB for Midas
Just wonder if it will be ok with a 1380cc? It says ideal for small bore engines and some 970/1071 cc cooper S
Re: LCB for Midas
Yes it should be fine due to the shape of the subframe on the metro which is different to the minis in the exhaust area. Remember that blocks on the 970 and 1070 are shorter, so the head fits lower, therefore manifold needs to be shorter on the mini. Same effect, different reason.
- minisweden
Re: LCB for Midas
You are absolutely right there, but I was thinking more in terms of it being efficient enough? Will it flow ok?
Re: LCB for Midas
Yes it will flow fine. That's what I am using on my 7 ports, in stainless.
- minisweden
Re: LCB for Midas
Thanks, Looking forward to the winter. It´s going to be fun fitting all the goodies in the cold months....
Re: LCB for Midas
Re: LCB for Midas
There is an issue with the bore diameters in relation to the engine capacity. Consult David vizard's book for details.
