Found a box of Bronze bits
chrismahon
Post by chrismahon »
Stuff keeps turning up. I have a load of original sales literature for bronze and gold plus unused bronze build manual which I will sort out and post. In the meantime I uncovered a box in the shed marked 'Bronze bits' leftover from breaking a 1986. It contains:-
Horn -Lucas25H
Front indicator/ sidelight units -R & L pair
Rear fog lights, 3 off, one new
Rear window cast hinge, drivers side
Bonnet pivot pins
Choke cable assy
Bonnet latch assy, both parts
Top engine tie bar mounting bracket
Rear window strut mounting brackets
Wiper motor only, SEV unit
Heater Motor,Lucas
Gearbox remote casting rear rubber mounting
Handbrake handle grip
Radiator mounting bracket set
Interior light door switches
Washer jets
Flasher units, 2 different types
Assorted small qty of imperial nuts and bolts
Anyone interested. Would prefer all went in one go, collected from SE Staffordshire. But is only an A4 size box so could post.
johnnyfixit
Re: Found a box of Bronze bits
Post by johnnyfixit »
pm sent Chris
graemedench
Post by graemedench »
I thought you'd be the person for those :)
How you getting on?
chrismahon
Fine thanks Graeme. If Johnny has these bits there is just the literature to sort and go. Gold went for £1200 to first viewer -eye for a bargain obviously. Packing, sorting and building/ repairing chicken coops as fast as able as time is running out. Hankering after a Fergie TE20 tractor with plough but advised to buy one over there because of shipping cost.
Return to “For sale”
