midas mk2 side glass
Hi, does any members know what right side drivers door glass is used? mine is scratched and would like to replace. also the outside window brush? thanks,Bob p.s. the car got 3rd. place in class at a large car show in new york on long lsland. first show and a real attraction!
Re: midas mk2 side glass
The glass is custom made, you should be able to get another made up using the original as a pattern, the whole window frame has to come off to do it. The brush I believe is just an aftermarket one, the seals suppliers over here look to have the right brush seal, then cut to length.
its 10 mm u channel the smallest channel on woolies.co.uk
