A Series Iskanderian (Isky) valve springs and alloy caps
Re: A Series Iskanderian (Isky) valve springs and alloy caps
what do they do are they performance enhancing
All That Glisters
If you have had a bit of work done on your car (camshaft, carb etc) and the valves are starting to bounce then you need to fit stronger valve springs and these look just the boys for you, but I suspect that fitting them on a stock engine would probably sap a bit of power because the buggers will take a bit more squeezing than the valve springs that you've already got.b1zbaz wrote:what do they do are they performance enhancing
Watch some clever dick prove me wrong.
Go on you know you can't resist a challenge.
Question is who will it be?
Do you feel lucky?
Go on punk make my day.
Stronger valve springs and weaker caps doesn't seem a good combination. I expect they help to wear out your cam and followers, too.
