There have been bits of engine sitting on the bench for a while now and it is time I did something with them. So I thought to myself: "What will an engineering shop need to see?" I have the block (with big-ends attached), crank, old bearings to determine size, pistons, rods, bare head, and the flywheel and backplate. I loaded these heavy bits of metal into my trusty Bora's boot (big enough to swallow 8, possibly even 10 12" wheels with tyres so no problem with this lot!) and am about to head off to a couple of engineering shops to get some quotes; the bores look good but I am no expert. I'll get some idea of the cost of a new set of pistons (next size up if needed) with a higher compression, full balancing, possibly lighten the flywheel and backplate with all new bearings and a much modified version of my head. Then I will start saving. Eek...
I want to recondition the Mistral alloys (still after a centre cap to replace the missing one as I only have 3...) but to do this I needed to make a frame to move the shell around on (this will probably made in due course) or buy some more axle stands. Or get myself another set of wheels. Thanks to a very helpful user on The Mini Forum (Cheers Matt!) I was able to get hold of a set of 4 steel wheels and tyres for the grand total of nothing. Nada. £0. Christmas has come early! So the alloys were whipped off and replaced with the steelies. I'll get the tyres taken off then have a look at getting all the paint and dirt off the alloys before painting. I am thinking black/polished rim to be a good contrast to the colour I am thinking of painting the car (Orange)... Any other suggestions?
Block on bench
Crank which looks good generally - I am hoping that it will need nothing more than a polish.
The very standard cylinder head. This will not look like this by the time I'm done with it. Expect bigger valves and porting.
Standard size low compression pistons. Not long for this world...
Old bearing shells and cam followers - they were just in the same box - and there are 4 more followers and plenty more bearing shells!
Flywheel and backplate. Time to lighten???
Free steelies!!
Alloys now off the car awaiting removal of the tyres.
Looking like a proper project now with dirty steels...
