My Mk1 had the radius arms reversed when I took them off the other week. Plus my brackets have a slot cut into them to presumably allow some form of toe-in/toe-out adjustment. However, the camber cannot be changed.[/quote][/quote][/quote]MrBounce wrote:[quote="Alan D]
Stuart has forgotten about Bronzenuts dodge of reversing the radius arms, that I'm lead to belive gives you instant negative camber.Alan
You'd need to use wheel spacers then, if you reversed the radius arms - my Mk 2 had minimal space between the coilovers and the tyres - at the time I had it, I think I put 5mm spacers on to give a bit of clearance.
On that subject, can you still get longer wheel studs? When I eventually fit 175/60 13 tyres to the rear wheels of the Mk 3 (to match the ones on the fronts), I think there might be a clearance issue between the tyres and the subframe brackets where the radius arms mount. It might be posssible to grind away enough metal to cure this, but I won't know until I fit the larger tyres, and that won't happen for a while yet.
