So out came the persuasion tools.
With just 2 bangs the outer CV snapped loose and I could remove the drive shaft.
Then on the other side also 2 bangs and also the outer CV came loose. Cut the boot loose, disconnect the hub and result:
So coming Friday I hope to get the subframe out and start cleaning the engine bay.
