Powerflex bushes are rubbish?
I just installed the new Powerflex bushes in my lower front suspension arms like this:
The blue ones are actually purple.
I expected a bit of a fight but they just slide in. To make matters worse the yellow ones (p/n pff63-203) are undersized. The have an outside diameter of 26mm while the hole in the arm is 27mm. The rubber that came out is 28mm so that was free of any play while the new ones have noticable play. How are these thing going to keep my wheel steady with so much play in them? Has anyone experience with Powerflex bushes? Is this normal?
Re: Powerflex bushes are rubbish?
Do they still have the play after the tube has gone in?
All the ones I've fitted have slid in but I wouldn't expect play after the tube has gone in.
Yes there is still a lot of play with the stainless steel tube in. The purple ones went easy in as well, but have the perfect fit. With the steel tubes in these feel solid. But the yellow one can be rocked fore and aft and you see them moving. I hope Powerflex have an answer to this, else I have to install original ones or install a 1mm thick steel sleeve.
Something not right there then Hans. I haven't tried their inner bushes as the ones I made are still going strong in that position, I have their bushes on the ARB with no problems at all.
I've been contacted by Powerflex. I hope they have a solution for me. Pretty annoying this. Without the arms I can't put the subframe back into the car and build the suspension up. I should be getting my engine back within a few weeks so the schedule is getting a bit tight.
Just an update, I've had contact with the engineering department and they intend to make a correct size bush for me and then will catalogue it. I need to take measurements from my suspension arm unless someone in the neighbourhood of Powerflex has the correct spare suspension arm in the garage and is willing to lend it to Powerflex. Possibly the undersized bush is for a pre-84 Metro but it would be nice if someone could confirm that. My suspension is from a 1989 1.3l Austin Metro, so the post 84 suspension. If anyone can comment on this please do. This is an almost unique opportunity to have the perfect bush manufactured.
I'll have a look tonight Hans, I might have written down the dimensions when I made my own, mine is an 89 frame.
Rich wrote:I'll have a look tonight Hans, I might have written down the dimensions when I made my own, mine is an 89 frame.
Thanks Rich, then I can compare your measurements with mine.
This is how my eye ends look like:
To my surprise the OEM bush FAM5006 is used for pre and post 84 Metro's, so that dimension never changed.
Just looked in my book of measurements and they aren't in there unfortunately.
Return to “Mk 3 Convertible”
