Finally I had time to do some work on the Midas.
I let the paint on the tank dry for a week, unfortunately temperatures are getting lower so the paint still felt soft and tacky. It had been better if I only had primered it and should have painted it after the sealing process. Anyway to seal the inside of the tank I had bought this:
First I used the cleaner to degrease the tank. This is nasty stuff and I had trouble keeping it in the tank. It just dissolved the tape I had used to close all gaps. After a few hours I removed it, flushed the tank with water and let it dry. This time in the house near the heater.
Today I mixed the epoxy and poured it in the tank. Closed all holes:
And after 20 minutes of continuous rotating I poured the remains out, but nothing came out.
Now the tank has to dry for 5 days at room temperature. So I converted the keyboard stand into a fuel tank stand:
(I can't play anyway, bought the keyboard a year ago but I lack all talent. My son is the only one playing on it)
With the tank aside I paid attention to a few small items. I painted the tank bracket that's on the body and removed the fuel pump, because I noticed cracks in the bobbins:
This was caused by the asymmetric design of the pump bracket:
I just ordered new bobbins and have started on a symmetric bracket.
The fuel transmitter looked like this on the tank when I removed it:
Now cleaned, stripped and painted it's waiting to get in again:
Also this week I received my fuel tank vent valve:
Very tiny, but expensive. Around 60 euros including shipment. It comes without any installation instructions so I had to find out by blowing on it what the correct position should be. If installed upside down it blocks everything because it is also a safety valve when you flip the car. So I'd better install it the right way up.
Also I am busy ordering stuff to connect the hoses the proper way. There are quite a few steps, f.e the tank transmitter has a connection of 6mm, while the fuel pump needs a 12mm hose. I found this company that can supply the proper hose joiners:
http://www.advancedfluidsolutions.co.uk ... 1337-p.asp
But they have not responded to my email so I will give them a call this week.
TBC.
