Gold Convertible Auxiliary Gauge Cluster
- Contact:
I thought the Midas could do with an extra gauge or two....
max midas
Re: Gold Convertible Auxiliary Gauge Cluster
'Tyre pressure - check
Windscreen washer bottle level indicator - check
Seat angle adjuster - check
Number of small stones caught in well just in front of front tyre - check ....
You could spend the whole journey trying to remember what that little red warning light was meant to indicate.
- Contact:
Ah the front tyre well is great around here. They seem to surface the fen roads with very loose chippings so they fill up the wells almost instantly!
max midas
I often wonder how much faster I'd go and how much cheaper to run if I emptied the front tyre wells more frequently.
