Page 2 of 2
Re: Rear frame MKII
Posted: Tue Oct 02, 2018 5:19 pm
by ilmung
Till now I did not find anything which may suppose Brain changed the position of the frame .
But inside there 's something that determine the position of the bolts of the frame , I make tomorrow some pictures so you will understand better .
Is there any possibility to get in touch with Brain ?
Re: Rear frame MKII
Posted: Tue Oct 02, 2018 5:45 pm
ilmung wrote:Till now I did not find anything which may suppose Brain changed the position of the frame .
This is Brian, although he hasn't visited the forum for quite some time
http://midasownersclub.co.uk/forums/mem ... file&u=480
Re: Rear frame MKII
Posted: Tue Oct 02, 2018 9:58 pm
by ilmung
Hi , does someone know the exact diameter of the tower holes in the grp ?
Re: Rear frame MKII
Posted: Wed Oct 03, 2018 9:31 pm
by ilmung
Hi Stuart
In annex you can see what I mean what Brian did to fix the rear frame at a certain position .
The place of the system to fix the bolts are just near the middle tunnel , right side , seen from the back of the car .
And you are right ,Brian did change the position of his rear frame some mm ( +- 6 mm) to the left , also seen from the back of the car .
Re: Rear frame MKII
Posted: Sat Dec 01, 2018 9:16 pm
by Chris59
On my own Mk2, the bolts, who seems originals, are 3/8.
I've just remove the rear subframe as it is a perfect candidate for an hot galvanisation treatment, enhance by a pair of Stainless steel brackets to hold the others ends of the trailing arms studs.
