Rear shock absorbers
Re: Rear shock absorbers
I'm still exploring replicating the original dual rate springs. My last mk3 had according to the service diary 150lb/in springs with a short 4lb/in run flat. That meant it wasn't at full damper extension at rest. It gave a nice ride as I remember and sat at the right height too.
I know my needs have changed a little since then, so I may end up with something much softer. It'll be the front that will be more challenging I imagine.
Hi all,
a follow up question concerning rear coilovers...
what size of C spanner is required to adjust the ride height without knocking all of my knuckles off using an inappropriate tool ?
I see that DemonTweeks sell a very comprehensive set of different spanner sizes, and for very reasonable prices, so that is where I am going once I know what size to get.
I bet the next questions is going to be: what coilover system is fitted (GAZ, SPAX etc). Don't know yet, need to get under the back end to check, but hopefully they are all much of a muchness.
Dave
Dave
Gaz use a 76 mm C-spanner. No doubt yours will have non height adjustable Spax dampers.
yes, I need to get under the car to find out I guess....going to try and blag my local KwikFit to put it up on the ramp for 5 minutes tomorrow !!Stuart wrote:Gaz use a 76 mm C-spanner. No doubt yours will have none height adjustable Spax dampers.
I've got two types which take 2.25" springs and the seats are 75 mm diameter
ah well, as Stuart so rightly said...I have non-adjustable coilovers on my car !! need to go shopping, so I had best read the rest of this thread to determine which ones to go for !
I have read the thread, and my non-engineer brain cannot cope with all of the alternatives being discussed.
So, can someone please point me to a spec or supplier of coilovers for road (NON TRACK) use.
Many thanks
Dave
Many thanks
Dave
I'd strongly recommend giving Alistair Courtney a phone call
Yes Kelvin I was going that way myself !!
Dave
Dave
I have a question about lowering my rear ride height. I have non adjustable Spax dampers which are quite old (so probably no more oil in them) and 100lbs springs. Preload is quite high on these dampers. I need to lower the car at the rear about half an inch to get a proper tyre gap (probably the gap will be a lot bigger if I remove all the tooling from the boot!). What would be wise? Do I need to buy new adjustable shocks? If yes, what's the best buy for the Midas right now? Or is it possible to modify the springs? F.E. by chopping a piece off, or do straps exist that can tie down 2 loops?
