wiring a mess, need help
Please post general information for the interests of Midas Owners Club members here.
1971saab
Post by 1971saab »
I live in USA and bought a mk1 midas on e bay. well when I got the car, I saw that a p.o. added a gm type fuse box under the dash just in front of the shifter , well what a mess. No dash gauges work and only some lights. I can only go by what I see in pics. that it should have a 4 fuse type box in the engine bay just to the right of the battery. he probley pulled the wires through the fire wall and wired them into the gm box. Well, I will like to put it back to original. Do I need a 4 fuse type box from a mini? also what colors are positive, key off , key on ? please any pics. color codes or diagrams will help so much . I'm a new member on the other side of the pond. Thanks Bob P.S. vin# D020159
Re: wiring a mess, need help
Welcome to the forum bob. I hope someone can pick this one up and answer it for you.
Post by mikeeskriett »
Hi Bob,
The standard Mini fusebox is correct for a mk1/2 Midas. The colour coding is usually as per a Mini so a Haynes (book of lies) manual should give you the information you need.
From Memory...
White/Red - Starter Solenoid feed
White - Ignition
Purple - Permanant Live
Green - 1st click on the key (sometimes light green with white stripe
This may be of use
http://www.minifinity.co.uk/forum/viewt ... 07&t=80766
This should be about right for your car.
http://www.auto-wiring-diagram.com/1389 ... ecial.html
Mike
Return to “Information for the interest of Midas Owners Club members”
