+30 rings for a set of 21251 1275 Pistons
graemedench
Post by graemedench »
Anyone got a set kicking about? seem that what was once a common size is no longer easy to get. My reason is everything is tiptop and I'd like to replace them just to freshen up the engine. bores are all fine so I'd rather not have to fork out for rebore and new pistons. From what i'Ve read the rings for the 21250 will also fit.
Re: +30 rings for a set of 21251 1275 Pistons
Yes the +30 rings are hard to get although I got a set from a specialist piston supplier a couple of years back. Try thorntons of Shrewsbury. Telephone: 01743 357081. http://www.fwthornton.co.uk
graemedench
Thanks David I'll get on it :)
Return to “Wanted”
