radiator hose support
From the beginning of owning this car I had problems with the radiator hose that runs from the waterpump to the lower LH corner of the radiator. I believe the original Metro item is a metal pipe but on my Midas it is a rubber hose. It tends to hang on the Y-shaped engine bracket and sometimes comes close to the pulley.
I installed a new hose during the rebuild but the problem was still there despite a bit of fiddling:
Therefore I built a small "cradle bracket" with a piece of 3mm rod and a strip of steel:
End result:
You can still see the indent the engine bracket left on the hose.
Next step will be a similar solution to the other radiator hose that has the same problem.
Re: radiator hose support
Post by lankyjames »
Hans Efde wrote: Next step will be a similar solution to the other radiator hose that has the same problem.
You mean the one that likes to feed itself to the alternator fan?
Post by max midas »
That's a very neat fabrication.
If it's still a problem try these:
http://www.apmotorstore.co.uk/alloy-pip ... iners.html
Should be able to find the correct diameter, and with a couple of stainless clamps you'll be sorted.
I found the stainless steel tube off a broken HENRY vacuum did it for me. Nice piece of stainless tube and just the right diameter. :D
Yes, but mine has the problem near the last bend where it hangs on the wiring and distributor.
manifold wrote:I found the stainless steel tube off a broken HENRY vacuum did it for me. Nice piece of stainless tube and just the right diameter. :D
That's a solution although I think the original Metro tube had a slight bend to pass the Y-bracket with proper clearance.
Post by max midas »
Try this then:
http://www.apmotorstore.co.uk/alloy-pip ... lbows.html
Starting to sound like a rep for the company :D
Post by max midas »
Glad you said a broken vaccuum cleaner, had visions of a really dusty house or a midget house cleaner ;)
