Here's a shot of us on display, more in the same timeline at flickr.com:
No idea, but I can check. I have a stronger spring which I can test. But also the engine builder will have a look at the carburettor this week for adjustment. It's a temp fix though just for running in the engine. Fuel injection should solve all the problems (and probably generate a few new ones) which will be a nice autumn/winter project.Rich wrote:Both cars are looking good Hans. Would leaning out under load be something to do with the piston spring being a little weak for the engine?
I'm stabbing in the dark here, but it sort of makes sense to me.
This evening I visited the engine builder who adjusted my carb. According to him a strong spring is only necessary if you want to change the powerband of the carb. With a stronger spring the powerband in which the carb works is put at a higher level. He changed the oil in the damper for a thick engine oil. I usually use ATF fluid but he put 10W40 or even thicker in. This increases the torque of the engine. We slimmed the needle a bit more down and adjusted the CO at stationary. The engine pulls fantastic but still in 4th gear above 4000rpm I get lean figures on my display. But according to him that's no problem, modern engines run lean in the upper band as well to conserve fuel. As long as the engine isn't holding back, it's okay. Anyway it is amazing already how fast this engine is, and it still needs to run in. Can't wait to get the ECU in and put it on a rolling road.Hans Efde wrote:No idea, but I can check. I have a stronger spring which I can test. But also the engine builder will have a look at the carburettor this week for adjustment. It's a temp fix though just for running in the engine. Fuel injection should solve all the problems (and probably generate a few new ones) which will be a nice autumn/winter project.Rich wrote:Both cars are looking good Hans. Would leaning out under load be something to do with the piston spring being a little weak for the engine?
