Domino pimlico
Domino1384
Domino pimlico
So I now am the owner of a domino pimlico I bought it of my dad!
It's a 1966 988cc donor
Was built in 1987 and the current spec is;
998cc bored to 1014cc
Flat topped pistons
12g295 head
Rim flow valves
Fast road cam
Solid rockers
Duplex timing chain
Lightened flywheel
It has a piper x magnum 2780r cam
Vs4 valve springs
Cooper s valve retainers
Gas flowed head
32mm inlet
27mm exhaust
Had a 60 thou skim
And has a 10.26.1 compression ratio
And a AIF6 44 carb with bdl needle and red spring
Pick up this Saturday
Will post more update soon
Kerb weight is only 542kg so lighter than the mini also
Edited by Richard1384, 29 July 2013 - 01:45 PM.
Flat topped pistons
12g295 head
Rim flow valves
Fast road cam
Solid rockers
Duplex timing chain
Lightened flywheel
Vs4 valve springs
Gas flowed head
32mm inlet
27mm exhaust
Had a 60 thou skim
Re: Domino pimlico
Nice one Richard, I'm amazed by how light it is, it should go well.
Domino1384
Re: Domino pimlico
Cheers Stuart i will post some pictures tommorow (sat)
Re: Domino pimlico
I've always liked the Pimlico. Nice car, hope you enjoy it
Sent from my Nexus 7 Using ForumTouch for Android
Domino1384
Re: Domino pimlico pictures added
Re: Domino pimlico
Like i said, Nice car.
excellent fixer upper
johnnyfixit
- Contact:
Re: Domino pimlico
Nice to another 4 seater kit car MK1 no troubles with head room in these and the kids still love it ! been a while but never left just skint.
Domino1384
Re: Domino pimlico
Cheers for comments .
Clutch bellhousing of to sand blasting tomorrow along with engine mounts
Domino1384
Re: Domino pimlico
Clutch housing has been short blast and sump plug has been helicoiled.
Engine and gear box have been cleaned ready for paint and reassembly
