MG TF radiator
(will fit a MK1/MK2 Midas with little mods, bottom mounts are the same distance as the standard metro /allegro mk1 radiator), aluminium so lightweight, cross-flow including fan.
Rad Mounts:
4x MG TF rubber mounts for the radiator
Silicone hoses:
2x ASH 30mm 45 degree (for the bottom hose)
2x ASH 30mm 90 degree (for the top hose)
Stainless Pipe:
1x ASH 1m x 32mm OD (for the top hose)
Fan Switch:
1x 32mm including temp switch
Clamps:
10x 30-40mm stainless pipe/hose clamps
This full kit should be enough to convert your MK1/2 to an upgraded aluminium radiator (which can be easily source and replaced in the future), replace the aging rubber hoses with stainless / silicone, add a fan switch (as the rad doesnt have one built-in) and secure with quality stainless clamps.
I will be putting these on ebay but thought I would offer it here first (as these are appropriate!), entire lot cost me around £100, will take sensible offers for the lot - collection preferred but of course I can post!
