windscreen gasket
windscreen gasket
Post by axshack »
ok, folks, next question !
my windscreen seal is beyond redemption so needs replacing !
I understand that the Reliant Fox seal was used originally - so who knows where Reliant sourced it first?
Better still, I reckon WOOLIES can supply providing someone can tell me the sizes of the channels to fit the glass and the body.
I assume that these were already fitted by the factory back in the day, so any pointers will be gratefully received.
This is the woolies link: http://www.woolies-trim.co.uk/c-122-screen-section.aspx
I need to get this done asap, so any help will be very gratefully received
Dave :)
davidj
Re: windscreen gasket
Post by davidj »
Hi David
There is reference already on the forum, try a search such as Windscreen Rubber. Failing that talk to Alastair Courtney at Alternative Cars or on this Forum.
Regards Davidj
sherwood-ranger
Post by sherwood-ranger »
Hi, I tried Woolies a couple of years ago and they did not carry the right size.
Post by axshack »
Hi Stuart,
many thanks for that...looks like a solution
think I will invest in 12 feet of that
Glad to be of assistance Dave. WR64 is dimensionally closer to the Reliant seal, however the body on my car isn't 5 mm thick, hence me thinking WR66 to be better suited. These seals don't have the additional 7 mm flap that the Reliant seal has, so won't look exactly the same.
Post by axshack »
just so long as it stops the weather coming in I guess it will do !! thanks a lot !
